Flexovit Delta Sanding Abrasive 94mm
SKU: 114335
€9,95
  • High‑performance aluminium oxide abrasive
  • Heavy‑duty paper backing for durability
  • Delta shape fits most delta sanders
  • Hook & loop fixing for quick sheet changes
  • Perforated for effective dust extraction
  • Suitable for wood, paint and metal
  • Size: Delta Shape, 94mm
Flexovit Delta Hook & Loop Sanding Sheets are manufactured from tough, sharp, high‑performance aluminium oxide and combined with a heavy‑duty paper backing for excellent durability and long service life. Designed to deliver consistent results, they are suitable for sanding a wide range of surfaces.
The delta‑shaped sheets fit most makes of delta sanders. The hook & loop fixing system enables fast, simple sheet changes, while the perforated design allows effective dust extraction during use. Ideal for sanding wood, paint and metal. Size: Delta Shape, 94mm
The two mixed packs contain the following.
Mixed pack of 6: 2 each of 60G, 80G and 120G.
Mixed pack of 25: 5 of 60G and 10 of 80G and 10 of 120G.
Pack Quantity 25
Abrasive Grit Mixed
EAN Barcode 3157625538498
