The ForgeFix ForgeFast Impact Bit Set is a durable and reliable solution for demanding fastening tasks. Designed for use with impact drivers, these bits are manufactured from specially engineered hardened steel to maximise strength, wear resistance, and overall lifespan.
Featuring an optimised shock-absorbing torsion zone, the bits are ideal for high-torque applications, helping to reduce breakage under load. The precision-machined tips ensure a secure fit, minimising cam-out and reducing the risk of screw head damage.
Impact Magnetic Bit Holder with a 1/4in Hex shank. It is made from specially engineered hardened steel that provides a long working life. Fitted with an ultra-strong magnet for a secure hold.
Contents:
