{"product_id":"forgefast-impact-screwdriver-bit-set-pozi-torx-mix-31-pce","title":"ForgeFast Impact Screwdriver Bit Set Pozi\/Torx Mix 31 Pce","description":"\u003cp\u003eThe ForgeFix ForgeFast 31 Piece Impact Bit Set contains a mix of Pozi and Torx drive screwdriver bits and impact bit holder in a strong storage case. Engineered for durability and high-performance fastening in demanding applications. Manufactured from specially hardened steel, these bits offer extended wear resistance and long service life.\u003c\/p\u003e\u003cp\u003eDesigned with an integrated shock-absorbing torsion zone, they are ideal for use with impact drivers and other high-torque tools. The precision-machined tips ensure a secure fit, reducing cam-out and minimising damage to screw heads.\u003c\/p\u003e\u003cp\u003eSupplied in a robust carry case for easy storage and transport.\u003c\/p\u003e\u003cp\u003eImpact Magnetic Bit Holder with a 1\/4in Hex shank. It is made from specially engineered hardened steel that provides a long working life. Fitted with an ultra-strong magnet for a secure hold.\u003c\/p\u003e\u003cp\u003eContents:\u003c\/p\u003e\u003cp\u003ePozidriv Compatible Bits (25mm):\u003c\/p\u003e\u003cp\u003ePZ1 ×2\u003c\/p\u003e\u003cp\u003ePZ2 ×5\u003c\/p\u003e\u003cp\u003ePZ3 ×2\u003c\/p\u003e\u003cp\u003eTORX® Compatible Bits (25mm):\u003c\/p\u003e\u003cp\u003eTX10 ×1\u003c\/p\u003e\u003cp\u003eTX15 ×2\u003c\/p\u003e\u003cp\u003eTX20 ×5\u003c\/p\u003e\u003cp\u003eTX25 ×5\u003c\/p\u003e\u003cp\u003eTX27 ×1\u003c\/p\u003e\u003cp\u003eTX30 ×5\u003c\/p\u003e\u003cp\u003eTX40 ×2\u003c\/p\u003e\u003cp\u003eAccessories:\u003c\/p\u003e\u003cp\u003e1 × 60mm Bit Holder\u003c\/p\u003e\u003cp\u003eFinish:\u003c\/p\u003e\u003cp\u003eBlack Phosphate\u003c\/p\u003e","brand":"Forgefix","offers":[{"title":"Default Title","offer_id":54118863307099,"sku":"114501","price":14.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114501_xl.jpg?v=1789794706","url":"https:\/\/www.axminstertools.com\/products\/forgefast-impact-screwdriver-bit-set-pozi-torx-mix-31-pce","provider":"Axminster Tools","version":"1.0","type":"link"}
