{"product_id":"forgefast-impact-screwdriver-bit-set-torx-12-pce","title":"ForgeFast Impact Screwdriver Bit Set Torx 12 Pce","description":"\u003cp\u003eThe ForgeFix ForgeFast Impact Bit Set offers a robust selection of TORX® compatible bits, designed for use with impact drivers and high-demand fastening tasks. Each bit features a standard 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e hex shank for universal compatibility.\u003c\/p\u003e\u003cp\u003eManufactured from specially engineered hardened steel, these bits deliver excellent wear resistance and extended service life. The integrated shock-absorbing torsion zone helps to withstand high torque loads, reducing breakage and improving performance in demanding applications.\u003c\/p\u003e\u003cp\u003ePrecision-engineered tips ensure an accurate fit, helping to minimise cam-out and prevent screw head damage for a cleaner, more efficient finish.\u003c\/p\u003e\u003cp\u003eImpact Magnetic Bit Holder with a 1\/4in Hex shank. It is made from specially engineered hardened steel that provides a long working life. Fitted with an ultra-strong magnet for a secure hold.\u003c\/p\u003e\u003cp\u003eSupplied in a convenient carry case for easy storage and transport.\u003c\/p\u003e\u003cp\u003eContents:\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e 11 x 25mm TORX® Compatible Impact Bits:\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e TX10, TX15, TX20 (x2), TX25 (x2), TX27 (x2), TX30 (x2), TX40\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e 1 x 60mm Bit Holder\u003c\/p\u003e\u003cp\u003eFinish: Black Phosphate\u003c\/p\u003e","brand":"Forgefix","offers":[{"title":"Default Title","offer_id":54118863241563,"sku":"114500","price":8.95,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114500_xl.jpg?v=1789794699","url":"https:\/\/www.axminstertools.com\/products\/forgefast-impact-screwdriver-bit-set-torx-12-pce","provider":"Axminster Tools","version":"1.0","type":"link"}
