The ForgeFix ForgeFast Impact Bit Set offers a robust selection of TORX® compatible bits, designed for use with impact drivers and high-demand fastening tasks. Each bit features a standard 1/4 hex shank for universal compatibility.
Manufactured from specially engineered hardened steel, these bits deliver excellent wear resistance and extended service life. The integrated shock-absorbing torsion zone helps to withstand high torque loads, reducing breakage and improving performance in demanding applications.
Precision-engineered tips ensure an accurate fit, helping to minimise cam-out and prevent screw head damage for a cleaner, more efficient finish.
Impact Magnetic Bit Holder with a 1/4in Hex shank. It is made from specially engineered hardened steel that provides a long working life. Fitted with an ultra-strong magnet for a secure hold.
Supplied in a convenient carry case for easy storage and transport.
Contents:
11 x 25mm TORX® Compatible Impact Bits:
TX10, TX15, TX20 (x2), TX25 (x2), TX27 (x2), TX30 (x2), TX40
1 x 60mm Bit Holder
Finish: Black Phosphate
Web Attribute Set Screwdriver Bits
EAN Barcode 5028485219590
