ForgeFix ForgeFast Pozi (PZ) and Torx (TX) compatible impact bits are engineered for durability and high-performance fastening. Manufactured from specially hardened steel, they deliver extended wear resistance and longer bit life, even under demanding conditions.
Featuring an optimised torsion zone, these bits efficiently absorb shock and reduce stress during high-torque applications, making them ideal for use with impact drivers. The precision-machined tip ensures a secure fit, helping to minimise cam-out and protect screw heads from damage.
Available in Pozi PZ and Torx TX Drive.
Choose from;
Pozi drive PZ2 in overall length 25mm or 89mm
PZ1 and PZ3 in length 50mm
Torx T15, T20, T25 and T30 in length 50mm
All supplied in packs of 2 except PZ2 in 25mm length that is supplied in a pack of 10.
Bit Size Pz2
Web Attribute Set Screwdriver Bits
EAN Barcode 5028485219675
