The ForgeFix ForgeFast Quick-Release Impact Chuck is designed for durability and reliable performance in demanding applications. With a 300mm overall length and 1/4 hex shank it gives a long reach and can be easily secured into a drill chuck.
The quick release 1/4 bit holder makes changing screwdriver bits or other hex shank accessories simple and easy and holds them securely in use with simple ejection when changing.
Manufactured from specially engineered hardened steel, this chuck offers extended wear resistance and longer bit life, making it suitable for heavy-duty use.
Finished with a black phosphate coating, it provides added protection against corrosion.
Web Attribute Set Hex Drive Bits
EAN Barcode 5028485220237
