Forgefix Pronged T-Nuts provide a reliable and straightforward solution for bolting into soft materials. Finished with a zinc plating, they offer enhanced corrosion resistance for long-lasting performance.
Applications
Ideal for use in soft furnishing industries where secure timber connections are essential. Commonly used in the construction of playground equipment and climbing walls.
Installation Guide
Use M6 T-Nuts with 6mm bolts, and M8 T-Nuts with 8mm bolts.
To install, tap the T-Nut into the substrate. The sharp prongs penetrate the material, anchoring the nut securely and preventing rotation during tightening.
Compatible with a wide range of bolting products.
Product Overview
A T-Nut (also known as a blind nut) is designed to fasten wood, particle board, or composite materials while maintaining a flush surface. Its slim body and flanged end resemble a T profile. The prongs feature serrations or hooks that embed into the material, ensuring strong retention.
Corrosion Protection
Zinc plating forms a protective barrier against oxidation. If the surface is damaged, the zinc acts as a sacrificial layer, preventing rust and preserving the integrity of the underlying metal. Zinc oxide, unlike iron oxide, does not degrade the substrate and can further shield it from corrosion—similar to the protective oxide layers found on aluminium and stainless steel.
Specifications
Finish: Zinc Plated
Sizes Available: M6 or M8
Pack Quantity: 10 per bag
Thread M6
EAN Barcode 5028485092407
