{"product_id":"forgefix-pronged-t-nuts-zp","title":"Forgefix Pronged T Nuts ZP","description":"\u003cp\u003eForgefix Pronged T-Nuts provide a reliable and straightforward solution for bolting into soft materials. Finished with a zinc plating, they offer enhanced corrosion resistance for long-lasting performance.\u003c\/p\u003e\u003cp\u003eApplications\u003c\/p\u003e\u003cp\u003eIdeal for use in soft furnishing industries where secure timber connections are essential. Commonly used in the construction of playground equipment and climbing walls.\u003c\/p\u003e\u003cp\u003eInstallation Guide\u003c\/p\u003e\u003cp\u003eUse M6 T-Nuts with 6mm bolts, and M8 T-Nuts with 8mm bolts.\u003c\/p\u003e\u003cp\u003eTo install, tap the T-Nut into the substrate. The sharp prongs penetrate the material, anchoring the nut securely and preventing rotation during tightening.\u003c\/p\u003e\u003cp\u003eCompatible with a wide range of bolting products.\u003c\/p\u003e\u003cp\u003eProduct Overview\u003c\/p\u003e\u003cp\u003eA T-Nut (also known as a blind nut) is designed to fasten wood, particle board, or composite materials while maintaining a flush surface. Its slim body and flanged end resemble a \u003cspecial id=\"32\"\u003e\u003c\/special\u003eT\u003cspecial id=\"32\"\u003e\u003c\/special\u003e profile. The prongs feature serrations or hooks that embed into the material, ensuring strong retention.\u003c\/p\u003e\u003cp\u003eCorrosion Protection\u003c\/p\u003e\u003cp\u003eZinc plating forms a protective barrier against oxidation. If the surface is damaged, the zinc acts as a sacrificial layer, preventing rust and preserving the integrity of the underlying metal. Zinc oxide, unlike iron oxide, does not degrade the substrate and can further shield it from corrosion—similar to the protective oxide layers found on aluminium and stainless steel.\u003c\/p\u003e\u003cp\u003eSpecifications\u003c\/p\u003e\u003cp\u003eFinish: Zinc Plated\u003c\/p\u003e\u003cp\u003eSizes Available: M6 or M8\u003c\/p\u003e\u003cp\u003ePack Quantity: 10 per bag\u003c\/p\u003e","brand":"Forgefix","offers":[{"title":"M8","offer_id":54163751829851,"sku":"113669","price":1.38,"currency_code":"GBP","in_stock":true},{"title":"M6","offer_id":54163751862619,"sku":"113670","price":1.24,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113669_xl.jpg?v=1790106292","url":"https:\/\/www.axminstertools.com\/products\/forgefix-pronged-t-nuts-zp","provider":"Axminster Tools","version":"1.0","type":"link"}
