Forgefix Threaded rods feature a bright zinc-plated finish, enhancing corrosion resistance while offering a cost-effective fastening solution for a variety of applications. They are compatible with multiple products, including Drop In Anchors and Masonry Anchor Shields.
These rods adhere to DIN 975 standards, ensuring quality and reliability.
Applications
Zinc Coating Benefits
The zinc coating serves as a protective barrier, preventing oxidation and prolonging the lifespan of the metal. If the barrier is compromised, zinc acts as a sacrificial anode to inhibit corrosion. Unlike iron oxide, zinc oxide forms a fine white dust that does not degrade the substrate’s surface integrity. This protective layer functions similarly to the oxide coatings found on aluminum and stainless steel, maintaining durability over time.
