These filters fit all the Fuji Q-Series Turbines. They are washable and easily replaced. These filters are a friction fit, replacing a filter in a matter of seconds. There is no need to take the turbine apart to remove or replace the filter. When installing always ensure that the filter fills the whole filter enclosure. Use something like a screwdriver to lever the filter into position. Size 210 x 125 x 50 mm.
Fuji
Fuji Spray 5029 Q Turbine Filter
| Web Attribute Set | HVLP Spray System Accessories |
