{"product_id":"fuji-spray-5432-2-quart-pressure-pot-assembly-kit","title":"Fuji Spray 5432 2-Quart Pressure Pot Assembly Kit","description":"\u003cp\u003eThe Fuji Spray 2‑Quart Pressure Pot Assembly Kit is designed to increase spraying efficiency by providing a higher‑capacity, lightweight material supply when used with compatible Fuji Spray HVLP turbine systems. By moving the material away from the spray gun, it significantly reduces hand and wrist fatigue while allowing longer, uninterrupted spraying sessions.\u003c\/p\u003e\u003cp\u003eWith a generous 2.25‑litre capacity, the pressure pot holds approximately twice the material of a standard bottom‑feed spray gun and over three times that of a gravity‑feed cup. This makes it ideal for spraying larger areas such as cabinetry, furniture, doors, or panels without frequent refilling.\u003c\/p\u003e\u003cp\u003eThe compact pressure pot design allows the spray gun to remain smaller and more manoeuvrable, making it easier to access tight spaces and spray at any angle, including upside down. Material flow remains consistent and stable throughout use, contributing to a smooth, professional finish across a wide range of applications.\u003c\/p\u003e\u003cp\u003eDesigned for use with 4‑stage Fuji Spray HVLP turbine systems, the 2QT Pressure Pot Assembly eliminates the need for a bulky external compressor when used with compatible equipment.\u003c\/p\u003e\u003cp\u003eWhat’s Included\u003c\/p\u003e\u003cp\u003e2‑Quart pressure pot with adaptor\u003c\/p\u003e\u003cp\u003e1,800mm material fluid hose\u003c\/p\u003e\u003cp\u003eQuick‑connect coupler\u003c\/p\u003e\u003cp\u003ePressure tube and check valve\u003c\/p\u003e\u003cp\u003eNipple caps\u003c\/p\u003e\u003cp\u003eImportant Usage Information\u003c\/p\u003e\u003cp\u003eTo use the 2QT Pressure Pot Assembly Kit, a 25ft standard air hose and a 2049F whip hose are required (not supplied).\u003c\/p\u003e\u003cp\u003eWhen used with the 9600‑G GXPC Spray Gun, a 9060 L‑Fitting (Order Code 103702) is also required.\u003c\/p\u003e\u003cp\u003eFor increased mobility and hands‑free operation, the Fuji Spray 2QT Pressure Pot Backpack (SKU 113002, sold separately) can be used with this assembly kit. When paired together, they create a fully mobile pressure‑pot spraying solution ideal for onsite work, large projects, and extended spraying sessions with improved freedom of movement.\u003c\/p\u003e","brand":"Fuji","offers":[{"title":"Default Title","offer_id":54117974999387,"sku":"101564","price":319.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/101564_xl.jpg?v=1789770974","url":"https:\/\/www.axminstertools.com\/products\/fuji-spray-5432-2-quart-pressure-pot-assembly-kit","provider":"Axminster Tools","version":"1.0","type":"link"}
