You can use the Fuji Spray Touch-Up Turbine Spray Gun any Fuji HVLP turbine. Just attach the quick-connect coupler to your hose and begin spraying. The Touch-Up gun comes with a 225cc capacity cup. It has a 1.0mm stainless steel needle, nozzle and aluminium aircap. The spray pattern is adjustable from round 6mm to 150mm. This spray gun is really handy for projects that require smaller touch-up work. The smaller size makes it ideal for hard-to-reach places, when your standard gun is too large.
It is essential equipment is cleaned after every job and operating instructions are followed. Failure to do so will void warranty
Web Attribute Set Spray Guns
