The Fuji Mini-Mite 4 Platinum system is an upgraded version of the Mini-Mite 4. It features a powerful four stage 8psi turbine unit and now incorporates the Fuji Heat Dissipation Box (HDB) found on the top of the range Platinum models. The HDB expels excess heat from the turbine resulting in much cooler operating temperatures and longer motor life. It is similar in most respects to the Q4 model but without the cost of the Q4's noise deadening pa
Fuji
Fuji Spray Mini-Mite 4 Platinum Turbine Unit & G-Xpc Gravity Spray Gun
| EAN Barcode | 5052511079322 |
