The Fuji Mini-Mite 4 Platinum system is an upgraded version of the Mini-Mite 4. It features a powerful four stage 8psi turbine unit and now incorporates the Fuji Heat Dissipation Box (HDB) found on the top of the range Platinum models. The HDB expels excess heat from the turbine resulting in much cooler operating temperatures and longer motor life. It is similar in most respects to the Q4 model but without the cost of the Q4's noise deadening package. Despite this, the Mini-Mite 4 Platinum is really as quiet as any comparable HVLP system on the market. All known coatings can be sprayed, including inks, stains, lacquers, varnishes, enamels, acrylics and so on, although some will have to be thinned before use. Included with the unit is Fuji's very comprehensive guide which covers all aspects of HVLP spraying in great detail.
It is available as the turbine only, or with one of three spray gun configurations to suit different needs. The T75G comes with a standard 600cc top-mounted gravity cup and features a non-bleed design, a side-mounted pattern control knob for easy fan size adjustment, and continuous positive pressure during spraying. The T70 includes a large 900cc bottom-fed fluid cup and shares the same non-bleed design and side-mounted pattern control for consistent, smooth application. For more detailed work and tight spaces, the G-XPC™ spray gun offers a compact, lightweight body with a 400cc gravity-fed cup, an ergonomic angled design for better balance, and a side-mounted pattern control knob. Its non-bleed operation ensures cleaner results with reduced overspray.
It is essential equipment is cleaned after every job and operating instructions are followed. Failure to do so will void warranty
Overall L x W x H 305 mm x 218 mm x 206 mm
Rating Trade/Professional
Sound Pressure Level LpA [Uncertainty K] 73 dB(A) [1.5 dB]
Motor Power 1,500 W
Plug Fitted UK 3 pin plug
Model Mini-Mite 4
Hose Length 7.6 m
Nett Weight 10.7 kg
Nozzle 1.4 mm
Voltage 230 V
Warranty Fuji Spray 2 Year Warranty
Gun Type G-Xpc Gravity
Web Attribute Set HVLP Spray Systems
