The Mini-Mite 5-stage Turbine develops approximately 9.5 PSI. This additional power allows you to apply heavier coatings and thicker viscosity finishes faster. It achieves optimum atomisation with all finishes, but particularly thick finishes and latexes. The time you spend preparing materials is much less.  In the Platinum systems, Fuji Spray has designed a unique method of removing any heat build-up from the turbine case. A heat dissipation bo
EAN Barcode 5052511079643
