Fuji’s Replacement Foam Pre‑Filters provide essential first‑stage turbine protection, capturing dust and debris before it reaches the main filter, helping maintain clean airflow, cooling performance and consistent spray quality.
A pack of two genuine Fuji Spray foam pre‑filters designed to fit the air intake of compatible Fuji D6 turbine systems. These filters act as a protective barrier for the turbine motor and primary filtration stage, supporting smooth and reliable operation.
Fuji Spray is a leading manufacturer of high‑performance HVLP spray equipment trusted by professionals worldwide. Their turbine systems and accessories are engineered for durability, clean airflow, and consistent finishing results, supported by a full range of genuine replacement parts to keep systems running at peak efficiency.
Specifications
Genuine Fuji Spray part: 4326‑2
Quantity: 2 foam pre‑filters
Compatibility: Fuji D6 HVLP turbine systems
Function: Captures coarse dust and debris before the main filter
Installation: Quick, tool‑free replacement at turbine air intake
Pair with Fuji’s main turbine filters for complete multi‑stage filtration, ensuring optimal airflow and prolonging the service life of your D6 turbine system
Web Attribute Set HVLP Spray System Accessories
EAN Barcode 5052511144006
