{"product_id":"fuji-spray-replacement-hepa-main-filter","title":"Fuji Spray Replacement HEPA Main Filter","description":"\u003cp\u003eThe Fuji Spray Replacement HEPA Main Filter is designed to maintain clean airflow and consistent performance in Fuji HVLP turbine systems. Acting as the primary filtration stage, it captures fine dust and airborne particles before they enter the turbine motor, helping to protect internal components and ensure reliable operation during spraying.\u003c\/p\u003e\u003cp\u003eRegular replacement of the main HEPA filter supports optimal airflow, cooling efficiency and spray quality, particularly in workshop environments where airborne dust and overspray are common. By reducing contamination within the turbine, the filter also helps extend motor life and maintain stable air delivery for a consistent, professional finish.\u003c\/p\u003e\u003cp\u003eManufactured to Fuji Spray’s exacting standards, this genuine replacement filter ensures correct fit and performance when servicing compatible Fuji turbine units. It is easy to remove and install, making it a simple but essential part of routine maintenance.\u003c\/p\u003e\u003cp\u003eFor best results, the HEPA main filter should be checked regularly and replaced as required, especially when used alongside pre‑filters in high‑dust or high‑use environments.\u003c\/p\u003e","brand":"Fuji","offers":[{"title":"Default Title","offer_id":54118788399451,"sku":"113730","price":29.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113730_xl.jpg?v=1789792036","url":"https:\/\/www.axminstertools.com\/products\/fuji-spray-replacement-hepa-main-filter","provider":"Axminster Tools","version":"1.0","type":"link"}
