The Fuji Spray Replacement Motor Intake Filter is designed to protect the turbine motor by filtering incoming air before it reaches internal components. Positioned at the motor intake, this filter plays a vital role in reducing the amount of dust, debris and airborne contaminants drawn into the turbine during operation.
By maintaining cleaner intake air, the motor intake filter helps support efficient cooling, consistent airflow and reliable performance—particularly in workshop environments where fine dust and overspray are present. Regular replacement reduces strain on the turbine motor and contributes to a longer service life for the machine.
Manufactured as a genuine Fuji Spray replacement part, this filter ensures correct fit and dependable performance with compatible Fuji turbine systems. It is quick and easy to remove and replace, making it an essential part of routine turbine maintenance.
For best results, the motor intake filter should be checked frequently and replaced as needed, especially when the turbine is used in dusty conditions or high‑use applications.
Web Attribute Set HVLP Spray System Accessories
EAN Barcode 5052511143986
