The Fuji Spray VALOR Mini H50 Air Cap Set delivers precision, ultra‑fine atomisation and fan‑pattern control tailored specifically for the VALOR Mini H50 spray gun, ensuring flawless spot repair, detailed finishing and consistent professional results.
A genuine Fuji Spray HVLP air cap and nozzle assembly engineered exclusively for the VALOR Mini H50. Each set provides a direct‑fit upgrade or replacement, enabling users to match atomisation performance to their coating type, viscosity and finishing requirements.
Fuji Spray is an award‑winning Canadian manufacturer known for high‑precision HVLP and compressor spray technology, trusted across automotive refinishing and specialist finishing industries. The VALOR line is purpose‑built for demanding modern coatings, offering accuracy, ergonomics and reliability across all refinishing stages.
Specifications
Available sizes: 0.8 mm, 1.0 mm, 1.2 mm
Precision HVLP air cap + nozzle set
Exclusively compatible with the VALOR Mini H50 spray gun
Designed for ultra‑fine atomisation and narrow, controlled fan patterns
Ideal for detail work, touch‑ups and small surface areas
Use alongside the Fuji VALOR Mini H50 spray gun and the wider VALOR system for a fully flexible workflow, allowing quick switches between nozzle sizes for fine detail, spot repairs or light‑to‑medium viscosity coatings.
Web Attribute Set HVLP Spray System Accessories
EAN Barcode 5052511146741
