This Gearshift Antique Pewter pen is an ideal gift for any car enthusiast. The mechanism takes its inspiration from a 5-speed H pattern gear shift. It even shifts just like the real thing, although putting in reverse will not erase what you have just written. The cap features a car tyre with tread and hubcap. The tip features the same tyre tread as the cap. The shifter handle includes an etched 5-speed pattern. And the industrialised crowbar clip attached to the body with two small screws rounds out the design. It is easy to make with a single tube and uses a popular Parker style refill. Requires 3/8 drill. When using a mandrel to make these pens, the 101665 Bushing Set will be required.
Pen Kit Classification Master
Difficulty Intermediate
Drill Bit Required 2026-08-03 00:00:00 +0100
Bushing Set Order No. 101665
Minimum Blank Size 19 mm x 19 mm x 76 mm
Pen Type Action Pen
Colour Pewter Web Attribute Set: Project Kits
EAN Barcode 5052511096770
