The design of the precision ground tip ensures rapid performance and fast waste removal when drilling into plasterboard. The result is a clean, correctly sized hole ready to take the yellow 15mm Gripit plasterboard fixing. The 1/4 hex shank allows you to use this flat bit in a standard drill chuck or a 1/4 hex quick-change bit holder.
Additional Accessories No
Web Attribute Set Flat Bits
EAN Barcode 5060434880222
