Gripit is a unique method of fixing an item to a plasterboard wall. Gripit fixings distribute the load over a much wider area compared to conventional fixings or plugs. Gripit is one of the strongest plasterboard fixings available.
The Gripit TV Kit contains 4 x Gripit Blue plasterboard fixings, 4 x locking washers, four flat washers, 4 x M8 x 20mm bolts and a 25mm Gripit flat bit. Using these heavy duty Gripit Bluefixings, you can be assured that your smart TV is secure.
N.B. These fixings are not suitable for cantilever bracket installations.
Web Attribute Set Plasterboard Cavity Fixings & Tools
EAN Barcode 5060434881298
