Shesto
Heavy Duty Polishing Kit for Steel, Stainless Steel & Ferrous Metals
SKU: 503938
£38.48
£32.07 Excl. VAT
  • Use with a drill, flexible shaft or bench grinder fitted with a taper spindle
  • Produces a mirror finish on steel, stainless steel, iron and (hard) ferrous metals
  • 2 x mops, 2 x compounds, 1 x pigtail arbor with 6mm shank
Used with a power drill or flexible shaft, this kit provides all you need to produce a mirror finish on steel, stainless steel, iron and (hard) ferrous metals. It only takes two easy steps, initially with the 100mm, 2 section stitched mop and grey compound, then followed by the 100mm x 25mm looseleaf, soft mop and blue compound. The kit also includes a pigtail arbor with a 6mm shank with which to mount the mops in a drill chuck.
Web Attribute Set Polishing Mop Accessories
