Used with a power drill or flexible shaft, this kit provides all you need to produce a high gloss finish on wood, hard and soft. It only takes two easy steps, initially with the 100mm x 4 section aluminium oxide abrasive lap, followed by the 100mm x 2 section stitched mop and buff compound. The kit also includes a pigtail arbor with a 6mm shank with which to mount the mops in a drill chuck.
Web Attribute Set Polishing Mop Accessories
