An economical way to purchase abrasive for orbital sanders. An aluminium oxide abrasive on an E-weight paper backing, the heavyweight paper reduces breakage at the securing point on orbital sanders. BW110 has a semi-open structure with antistatic properties to reduce clogging. It is especially suited to sanding hardwoods and is suitable for use on metal. It has a good stock removal rate even with low sanding pressure. BW110 is an excellent multi-purpose abrasive for use with powered sanders.
Available in a variety of grits.
Abrasive Type BW 110
Abrasive Backing Paper
Pack Quantity 1
Abrasive Grit 80
Web Attribute Set Abrasive Rolls
EAN Barcode 4045191715773
