These Hermes abrasive discs will shorten your machining times and are fitted with a hook and loop fixing for quick and easy disc changing. The aluminium oxide, velour-backed discs have antistatic properties and have an open grain coating to reduce clogging of sanding dust. They are easy to handle, as a result of the strong F-paper backing. BW114 is especially suited to sanding soft woods and for applications with high grinding pressure.
These discs are suitable to fit the Axminster Workshop AW200BDS Belt & Disc Sander - 230V.
Available in three different grits. Contains 10 x 200mm discs.
