Hermes
Hermes RB 377 YX Abrasive Belts 150 x 1,220mm
SKU: 110222
£16.58
£13.82 Excl. VAT
  • Polyester/cotton cloth backed aluminium oxide abrasive
  • High stock removal rates in the coarse grit range
  • Consistent surface quality in the fine grit range
To fit Axminster AS609, AS610, AS612, CCBDS69 and most other 6 x 9 belt and disc sanders. The polyester/cotton back combined with the resin bonded aluminium oxide grain mix produces a high stock removal with coarse grits, plus a consistent surface quality with fine grits. Smooth running and long lasting, perfect for abrading metals and sanding seasoned woods.
Abrasive Type RB 377 YX
Abrasive Belt Length 1,220 mm
Abrasive Belt Width 150 mm
Abrasive Backing Cloth
Pack Quantity 1
Abrasive Grit 60
EAN Barcode 4045191364032
