These Hermes RB377YX 150 x 2,000mm belts are suitable for the Axminster Engineering Series BS-150 Belt Linisher. The RB377YX material is a heavy and semi-flexible aluminium oxide abrasive cloth. The special aluminum oxide grain mix provides high stock removal in the coarse grits and gives a very constant surface quality in the finer grit ranges, the backing is a polyester/cotton cloth which ensures smooth running on our machines. All this makes it a perfect partner for our range of belt linishing machines whether you are using steel, stainless steel, aluminum or other types of non-ferrous metals.
Abrasive Type RB 377 YX
Abrasive Belt Length 2,000 mm
Abrasive Belt Width 150 mm
Abrasive Backing Cloth
Pack Quantity 1
Abrasive Grit 60
EAN Barcode 4045191485270
