Hermes VC153 Abrasive discs with hook and loop fixing, available in a full range of grits. Manual sanding/grinding of wood, filler, lacquer, primer and metal materials using random orbital, angle grinders and hook and loop orbital sanders. They have many applications and are particularly suited to sanding and finishing turned bowls. Available in 25mm (1"), 50mm (2") and 75mm (3") diameters in packs of 10 discs.
Abrasive Type VC 153 VEL
Pack Quantity 10
Abrasive Grit 180
Abrasive Disc Diameter 50 mm
EAN Barcode 4050806780459
