Layers of zirconium abrasive cloth, angled on a supporting plate and lasting up to 10 times longer than conventional fibre discs. As the material wears away it exposes a new, fresh face of abrasive therefore achieving much higher material removal. For use on wood, metal, painted surfaces and masonry. These are particularly effective for rust removal and general finishing. 115mm diameter, 22mm bore.
Hermes
Hermes Zirconium Flap Discs
| Disc Diameter | 115 mm |
| Abrasive Grit | 40 |
| Web Attribute Set | Angle Grinder Discs |
| EAN Barcode | 4038595530660 |
