The HiKOKI M12VE 1/2 Variable Speed Router is a quality trade rated router with plenty of power for all requirements. It features a powerful motor and variable speed with electronic control ensuring constant speed under load plus it has a 3-position turret depth stop with indicator. The speed range and excellent plunge depth allow you to undertake a wide variety of routing tasks, using 1/2 or 1/4 shank cutters. The handles are adjustable for convenience and comfort.
Supplied with 1/2 collet, 1/4 sleeve adaptor, side fence, 30mm template guide, tools and carrying case.
Collets Supplied 1/4 and 1/2
Rating Trade/Professional
Spindle Lock Standard Feature
Sound Power Level LwA [Uncertainty K] 94 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 83 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 8.9 m/s² [3.4 m/s²]
Motor Power 2,000 W
Plug Fitted 230V - UK BS89/13 13A Type G (2P+Earth)
Cutter Speed 8,000 - 22,000 rpm
Voltage 230 V
Web Attribute Set Routers
EAN Barcode 4966376295319
