{"product_id":"hultafors-hdcs4-heavy-duty-chisel-set-4-piece-6-25mm","title":"Hultafors HDCS4 Heavy-Duty Chisel Set, 4 Piece (6-25mm)","description":"\u003cp\u003eThe Hultafors HDC Heavy-Duty Chisels are ideal for tasks requiring strength and precision. Forged in one piece with continuous robust I-profile for extreme breaking strength and to maximize the power transmission down into the workpiece. A 25°; cutting edge provides an optimal ratio between sharpness and durability.The entire blade, including the handle, can be placed flat against the surface which allows you to cut parallel to a flat surface. Fitted with a grip-friendly Santoprene handle and impact resistant nylon striker. The striker canbe replaced when worn down. Each chisel is supplied in a practical holster. The holster can be attached to both a belt and a button on your work clothes. If your belt is thick, cut away the small pin on the cover.\u003c\/p\u003e","brand":"Hultafors","offers":[{"title":"Default Title","offer_id":54118577504603,"sku":"112852","price":136.7,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/112852_xl.jpg?v=1789787009","url":"https:\/\/www.axminstertools.com\/products\/hultafors-hdcs4-heavy-duty-chisel-set-4-piece-6-25mm","provider":"Axminster Tools","version":"1.0","type":"link"}
