The Hultafors HDC Heavy-Duty Chisels are ideal for tasks requiring strength and precision. Forged in one piece with continuous robust I-profile for extreme breaking strength and to maximize the power transmission down into the workpiece. A 25°; cutting edge provides an optimal ratio between sharpness and durability.The entire blade, including the handle, can be placed flat against the surface which allows you to cut parallel to a flat surface. Fitted with a grip-friendly Santoprene handle and impact resistant nylon striker. The striker canbe replaced when worn down. Each chisel is supplied in a practical holster. The holster can be attached to both a belt and a button on your work clothes. If your belt is thick, cut away the small pin on the cover.
Hultafors
Hultafors HDCS4 Heavy-Duty Chisel Set, 4 Piece (6-25mm)
| Web Attribute Set | Chisel Sets |
| EAN Barcode | 7317843906714 |
