The Hultafors HDC Heavy-Duty Chisels are ideal for tasks requiring strength and precision. Forged in one piece with continuous robust I-profile for extreme breaking strength and to maximize the power transmission down into the workpiece. A 25°; cutting edge provides an optimal ratio between sharpness and durability. The entire blade, including the handle, can be placed flat against the surface which allows you to cut parallel to a flat surface. Fitted with a grip-friendly Santoprene handle and impact resistant nylon striker. The striker can be replaced when worn down. Each chisel is supplied in a practical holster. The holster can be attached to both a belt and a button on your work clothes. If your belt is thick, cut away the small pin on the cover.
Chisel Blade Width 38 mm
Web Attribute Set Bevel Edge Chisels
EAN Barcode 7317843906615
