The Qvarfot Felling Axe is well suited to small-scale forestry tasks. The Qvarfot is useful for felling small trees, splitting, bucking and limbing logs. The dimensions and fine balance of this felling axe offer precise control when chopping. The 650mm long handle adds force and speed to the strike. Total weight: 1.26kg, weight of head: 0.85kg, length of handle: 650mm.
Hultafors Hults Bruk forged their first axe around 1697, so this Swedish company has plenty of experience. The axes are still hand forged, each head requiring 40 to 60 blows under a spring-hammer, while the skilled blacksmith manoeuvres the red-hot billet. This process not only shapes the steel, it changes its structure increasing its density and results in greater durability. The head is hardened and tempered to 56-57 HRC to give the best possible performance. The cutting edge comes ready sharpened and polished, at most a light stropping will be all it requires. The handle is selected, tight-grained American hickory with a natural linseed oil finish. A wooden wedge and a steel ring wedge ensure a secure, tight connection between head and handle. Each axe comes with a lifetime warranty on the forging, a protective sheath and care instructions.
Web Attribute Set Axes & Adzes
EAN Barcode 7391408417204
