Small, neat line level made of impact-resistant plastic with a vial and hooks at both ends. Hang the level on a tensioned string so that you can check the incline between 2 points. Made from ABS plastic which makes the level both light and durable. The tube vial is made of Plexiglas while the vial fluid is a low viscosity, oil mixture that gives the bubble the best possible conditions for movement.
Hultafors
Hultafors Plastic Line Level 80mm UZ8
| Web Attribute Set | Levels |
| EAN Barcode | 7317844028026 |
