The Hultafors Tri-Lok Pocket Tape is an accurate, durable and reliable tape ideal for the professional user, having polyester coated blade and clear 2-colour printing on a yellow background. Features a tough grey ABS case with a non-slip rubber grip pad. The Tri-Lok tape has an easy-to-use brake which holds the blade securely at the desired length, and the effective bump stop gives added blade and end-hook protection during use. It is also fitted with a belt clip and self-zeroing end-hook. Available with both metric and imperial graduations. The blade is accurate to EC Class I. Made in Britain.
Hultafors
Hultafors TL5ME Tri-Lok Pocket Tape 5m/16ft (Width 19mm)
| Web Attribute Set | Measuring Tapes |
| EAN Barcode | 7317843581119 |
