The Irwin Blue Groove 6X Stubby Wood Bit is designed for rapid wood drilling, offering six times faster penetration than standard flat bits. Its 'Tri-Flute' design ensures faster chip ejection, while the full screw tips make drilling effortless by pulling the bit through the material. The cutting spurs create clean holes with minimal breakout, and the tapered flute reduces binding. Heat-treated for extra durability, these 10cm (4in) long stubby bits are perfect for drilling through joists or in tight spaces, suitable for holes up to 5cm (2in) deep.
Drill Bit Diameter 22 mm
Overall Length \ Working Length 100 mm 50 mm
Web Attribute Set Power Auger Bits
EAN Barcode 5706919219940
