The IRWIN Blue Groove 6X Stubby Wood Bit Set is a fantastic choice for anyone needing efficient and reliable wood drilling. These bits are designed to offer six times faster drilling penetration than standard flat bits, thanks to their innovative 'Tri-Flute' design which allows for faster chip ejection.
The full screw tips ensure ease of use and pull through, while the cutting spurs produce clean holes with minimal breakout. Additionally, the tapered flute reduces binding, and the bits are heat-treated for extra durability. The stubby design, at 100 mm (4) long, makes them perfect for drilling through joists or in enclosed areas, and they are suitable for holes up to 50 mm (2) deep. This set includes five bits in sizes 16, 18, 20, 22, and 25mm, and comes with a free extension.
This set is perfect for anyone looking for high-performance wood bits that offer speed, precision, and durability. The compact design makes it ideal for working in confined spaces, and the variety of sizes ensures you have the right bit for any job.
Web Attribute Set Power Auger Bits
EAN Barcode 5706919220076
