The IRWIN® Blue Groove 4X Quick Change Extension is designed for use with 4X flat bits when additional drilling depth is required. Its quick-change mechanism allows for fast and secure bit swaps, improving efficiency on the job.
This model, IRW10502824, measures 300mm (12) in length and is built for durability and precision in demanding applications.
Web Attribute Set Hex Drive Bits
EAN Barcode 24721056016
