The Irwin Chisel Set is built for heavy-duty woodworking, combining durable construction with excellent sharpness and edge retention. Ideal for carving, cutting and removing wood, the eight popular sizes provide a versatile selection for workshop and site use.
Each chisel features a one-piece forged tool steel blade, specially hardened to maintain a sharp cutting edge for longer and reduce the need for frequent re-sharpening. The contoured, split-proof ProTouch™ handle provides a comfortable, controlled grip and helps reduce vibration and hand fatigue. A large metal striking cap withstands repeated hammer blows and helps protect the handle from damage. Each blade is supplied honed and sharpened ready for use.
Irwin Marples chisels combine a long-established woodworking heritage with durable materials and practical features designed for professional and demanding workshop use.
Supplied with;
1 x 6mm (1/4) Chisel
1 x 10mm (3/8) Chisel
1 x 13mm (1/2) Chisel
1 x 19mm (3/4) Chisel
1 x 25mm (1) Chisel
1 x 32mm (1-1/4) Chisel
1 x 38mm (1-1/2) Chisel
1 x 50mm (2) Chisel
1 x Wooden Storage Box
Web Attribute Set Bevel Edge Chisels
EAN Barcode 5706919779116
