The auger bit on this type has a point on the end, one cutting spur and a single spiral for rapid chip clearance. The single spur is easy to sharpen and the bits cut evenly and fast, even in the hardest of timbers.
N.B. As all the auger bits have to accommodate different machines they are supplied long and will need cutting with a conventional hacksaw blade to suit the specific machine for which purchased.
Shank Diameter 2026-08-03 00:00:00 +0100
Size 2026-02-01 00:00:00 +0000
Metric or Imperial Imperial
Bit Size 2026-02-01 00:00:00 +0000
Web Attribute Set Hollow Square Mortice Chisels & Bits
EAN Barcode 4560272502047
