Harima
Japanese Pattern Mortice Bits Only
SKU: 510311
£19.18
£15.98 Excl. VAT
  • Japanese pattern
  • Auger bit with a point on the end, one cutting spur and a single spiral for rapid chip clearance
  • Easy to sharpen single spur and the bits cut evenly and fast
The auger bit on this type has a point on the end, one cutting spur and a single spiral for rapid chip clearance. The single spur is easy to sharpen and the bits cut evenly and fast, even in the hardest of timbers.
N.B. As all the auger bits have to accommodate different machines they are supplied long and will need cutting with a conventional hacksaw blade to suit the specific machine for which purchased.
Shank Diameter 2032-05-01 00:00:00 +0100
Size 8mm
Metric or Imperial Metric
Bit Size 8 mm
Web Attribute Set Hollow Square Mortice Chisels & Bits Max Depth of Cut: 56mm
EAN Barcode 4560272502153
