{"product_id":"japanese-pattern-mortice-chisels-bits","title":"Japanese Pattern Mortice Chisels \u0026 Bits","description":"\u003cp\u003eThe design of the Japanese pattern could well reflect the use of softer timbers used in traditional Japanese furniture making, the auger having a deep, high ratio flute, quickly removing the longer slivers softwoods create. The auger bit on this type has a point on the end, one cutting spur and a single spiral for rapid chip clearance. The single spur is easy to sharpen and the bits cut evenly and fast, even in the hardest of timbers.\u003c\/p\u003e\u003cp\u003eThe chisel is finely ground and slightly tapered from the tips by 0.1mm to allow easy removal from the mortice. A deep waste slot prevents the waste material becoming jammed around the auger.\u003c\/p\u003e\u003cp\u003eThese mortice chisels and bits are made from the finest Japanese carbon steels, selected as ideal for these tools. Often imitated but never equaled.\u003c\/p\u003e\u003cp\u003eEither way, a high quality chisel will enhance your morticer's performance to a degree where once tried one you will never use a low quality chisel again. Admittedly, they are a big investment, but, what a difference!\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eN.B. As all the auger bits have to accommodate different machines they are supplied long and will need cutting with a conventional hacksaw blade to suit the specific machine for which purchased.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eFor individual specification, please see technical data sheet download.\u003c\/p\u003e","brand":"Harima","offers":[{"title":"Imperial \/ 1\" \/ 1 \u0026 3\/16\"","offer_id":54115894788443,"sku":"510284","price":95.28,"currency_code":"GBP","in_stock":true},{"title":"Imperial \/ 1\/2\" \/ 13\/16\"","offer_id":54115894821211,"sku":"510285","price":52.98,"currency_code":"GBP","in_stock":false},{"title":"Imperial \/ 1\/4\" \/ 13\/16\"","offer_id":54115894853979,"sku":"510286","price":42.48,"currency_code":"GBP","in_stock":true},{"title":"Metric \/ 10 mm \/ 13\/16\"","offer_id":54115894886747,"sku":"510287","price":44.98,"currency_code":"GBP","in_stock":true},{"title":"Metric \/ 12 mm \/ 13\/16\"","offer_id":54115894919515,"sku":"510288","price":52.98,"currency_code":"GBP","in_stock":false},{"title":"Metric \/ 16 mm \/ 13\/16\"","offer_id":54115894952283,"sku":"510289","price":52.78,"currency_code":"GBP","in_stock":true},{"title":"Metric \/ 20 mm \/ 1 \u0026 3\/16\"","offer_id":54115894985051,"sku":"510290","price":75.18,"currency_code":"GBP","in_stock":true},{"title":"Imperial \/ 3\/4\" \/ 1 \u0026 3\/16\"","offer_id":54115895017819,"sku":"510291","price":75.18,"currency_code":"GBP","in_stock":true},{"title":"Imperial \/ 3\/8\" \/ 13\/16\"","offer_id":54115895050587,"sku":"510292","price":38.98,"currency_code":"GBP","in_stock":true},{"title":"Imperial \/ 5\/8\" \/ 13\/16\"","offer_id":54115895083355,"sku":"510294","price":60.68,"currency_code":"GBP","in_stock":true},{"title":"Metric \/ 6 mm \/ 13\/16\"","offer_id":54115895116123,"sku":"510295","price":42.48,"currency_code":"GBP","in_stock":true},{"title":"Metric \/ 8 mm \/ 13\/16\"","offer_id":54115895148891,"sku":"510296","price":36.88,"currency_code":"GBP","in_stock":true},{"title":"Metric \/ 6 mm \/ 3\/4\"","offer_id":54115895181659,"sku":"702716","price":42.48,"currency_code":"GBP","in_stock":true},{"title":"Metric \/ 8 mm \/ 3\/4\"","offer_id":54115895214427,"sku":"702717","price":42.48,"currency_code":"GBP","in_stock":true},{"title":"Metric \/ 10 mm \/ 3\/4\"","offer_id":54115895247195,"sku":"702718","price":38.98,"currency_code":"GBP","in_stock":true},{"title":"Metric \/ 12 mm \/ 3\/4\"","offer_id":54115895279963,"sku":"702719","price":52.98,"currency_code":"GBP","in_stock":true},{"title":"Metric \/ 16 mm \/ 3\/4\"","offer_id":54115895312731,"sku":"702720","price":52.78,"currency_code":"GBP","in_stock":true},{"title":"Metric \/ 20 mm \/ 3\/4\"","offer_id":54115895345499,"sku":"702721","price":75.18,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/510294_xl.jpg?v=1789757341","url":"https:\/\/www.axminstertools.com\/products\/japanese-pattern-mortice-chisels-bits","provider":"Axminster Tools","version":"1.0","type":"link"}
