Axcaliber
JB Weld Perma-Lock High Strength Threadlocker 13ml
SKU: 114293
€8,95
  • High‑strength formula for demanding applications
  • Permanent bond—requires heat + tools for removal
  • OEM approved for securing bolts and fasteners
  • Suitable for mechanical parts, body assemblies, and hundreds of general fastening jobs
J-B Weld Perma-Lock Red is a high‑strength threadlocker designed for heavy‑duty applications where maximum resistance to shock, vibration, and impact is essential. Once cured, it forms a permanent bond that requires heat and hand tools to disassemble.
J-B Weld Threadlockers deliver a strong, reliable lock and seal for threaded fasteners across a wide range of mechanical and assembly tasks. Ideal for preventing fastener loosening caused by vibration or repeated movement.
Specifications
Temperature Resistance: Up to 148°C (300°F)
Suitable Bolt Size: 1/4 to 1
Web Attribute Set Superglues, Cyanoacrylates & Specialist Glues
EAN Barcode 43425271136
