This package comprises the Axminster / JSP APF 10 Powercap Powered Respirator Main Filters TH1P (Pkt 2), Peel Off Visor Overlay (Pkt 10) and the Pre-Filter Pad (Pkt 10).
The JSP Powercap Powered Respiratory protection system is a lightweight and ergonomic solution able to work efficiently in very dusty environments. How long filter cartridges last is down to the level of contamination in a particular working environment. Whenever possible check the airflow of the unit prior to use. To fit new filters align the fittings on the filter with those on the filter housing, push fit and tighten. Supplied as a pair, these filters feature a high capacity pleated filter cartridge giving TH1P protection. The high efficiency sub-micron particulate filters have a high impact polystyrene front and back.
Axminster / JSP APF 10 Powercap Powered Respirator Pre-Filter Pad (Pkt 10)
These pre-filters for the JSP Powercap Powered Respirator fit onto the main filter. They will greatly extend the useful life of the main filter by removing larger particles of dust contamination before the air passes through the main filter. Supplied as a pack of ten.
Axminster / JSP APF 10 Powercap Powered Respirator Peel Off Visor Overlay (Pkt 10)
These visor overlays protect the main visor of your JSP Powercap Powered Respirator and greatly extend its working life. Overlays are particularly useful when spraying or applying polish that may splash onto the visor. Supplied in a pack of 10.
Web Attribute Set Respiratory Protection
EAN Barcode 5052511080434
