This medium JSP Force 8 Twin Cartridge Half-Mask comes with two PressToCheck™ P3 high efficiency particulate dust filters. The Force™ 8 PressToCheck™ filters allow you to instantly check that you have the correct seal every time. The Force 8 features the Typhoon valve, which has very low breathing resistance, allowing you to breathe comfortably without fatigue.
Made from a durable thermoplastic rubber, the mask is comfortable and offers a superior fit to most face shapes. The carefully designed 4-point suspension harness has quick release buckles. The mask accepts the full range of low profile Force 8 filters. This gives the Force™ 8 the flexibility to be used for many applications, providing filtering protection against particulates, many gases and vapours.
JSP Force 8 respirators are reusable; they can be easily stripped, cleaned, maintained and reused for an indefinite period of time. Replacement filters whilst not indefinite, last far longer than single use disposable respirators. JSP recommend 1-3 days for high use, 3-5 days for medium use and 28 days maximum for light use.
Conforms to EN140.
For a useful cleaning guide, please refer to the Downloads section
Please note as this is a Health and Safety respiratory item, we cannot accept items for a refund once the packaging seal is broken and item has been worn.
Conformity EN140 (mask) EN143 (filter)
Web Attribute Set Respiratory Protection
EAN Barcode 5038428169080
