{"product_id":"jsp-force10-typhoon-full-face-mask-with-visor","title":"JSP Force™10 Typhoon™ Full Face Mask With Visor","description":"\u003cp\u003eThe JSP Force\u003cspecial id=\"10\"\u003e\u003c\/special\u003e10 Typhoon\u003cspecial id=\"10\"\u003e\u003c\/special\u003e is a lightweight, easily maintained full face mask with a panoramic visor and Class 3 heavy-duty filter connections.\u003c\/p\u003e\u003cp\u003eUsing extensive independent research into human face shapes, JSP has been able to refine the design for a comfortable fit with an effective face seal. Made from a durable thermoplastic rubber, the mask will fit most face shapes. The 5-point suspension harness and quick release buckles make it easy to adjust. The mask moulds to the shape of the face and padding provides extra comfort.\u003c\/p\u003e\u003cp\u003eThe optical Class 1 visor conforms to EN166.B impact protection (tested with a 6mm steel ball bearing travelling at 270mph). The completely clear panoramic visor maximises light levels within the mask giving optimum visibility. The visor has anti-mist and anti-scratch coating as standard and comes complete with a replaceable peel-off visor protector.\u003c\/p\u003e\u003cp\u003eThe unique Typhoon\u003cspecial id=\"10\"\u003e\u003c\/special\u003e valve has very low breathing resistance, which in turn reduces heat and moisture build-up within the mask. The Typhoon\u003cspecial id=\"10\"\u003e\u003c\/special\u003e valve allows you to breathe comfortably without fatigue.\u003c\/p\u003e\u003cp\u003eThe Force\u003cspecial id=\"10\"\u003e\u003c\/special\u003e10 Typhoon\u003cspecial id=\"10\"\u003e\u003c\/special\u003e is compatible with both JSP Classic filters and PressToCheck\u003cspecial id=\"10\"\u003e\u003c\/special\u003e filters. Using PressToCheck\u003cspecial id=\"10\"\u003e\u003c\/special\u003e filters allows you to check that you have the correct seal every time. The Force\u003cspecial id=\"10\"\u003e\u003c\/special\u003e 10 offers flexibility for many applications, providing protection against particulates, many gases and vapours.\u003c\/p\u003e\u003cp\u003eDisassembly, cleaning and maintenance are effortless with replacement parts available if necessary. JSP Force 10 respirators are reusable. For convenience, they can be easily stripped, cleaned, maintained and reused for an indefinite period of time. Replacement filters whilst not indefinite, last far longer than single use disposable respirators. JSP recommend 1-3 days for high use, 3-5 days for medium use and 28 days maximum for light use.\u003c\/p\u003e\u003cp\u003eConforms to EN140 optical class 1 EN166 B (impact) EN 136 (class 3)\u003c\/p\u003e\u003cp\u003eAn initial face fit test is recommended.\u003c\/p\u003e\u003cp\u003ePlease note as this is a Health and Safety respiratory item, we cannot accept items for a refund once the packaging seal is broken and item has been worn.\u003c\/p\u003e","brand":"JSP","offers":[{"title":"Default Title","offer_id":54118337380699,"sku":"105821","price":121.58,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/105821_xl.jpg?v=1789776307","url":"https:\/\/www.axminstertools.com\/products\/jsp-force10-typhoon-full-face-mask-with-visor","provider":"Axminster Tools","version":"1.0","type":"link"}
