{"product_id":"jsp-springfit-fold-flat-valved-respirator-ffp2-pkt-10","title":"JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)","description":"\u003cp\u003eThe SpringFit\u003cspecial id=\"10\"\u003e\u003c\/special\u003e fold flat disposable mask incorporates JSP’s Integrated Structural Comfort\u003cspecial id=\"10\"\u003e\u003c\/special\u003e. This takes the form of a unique endoskeleton structure inside the mask, resulting in an unrivalled secure fit. The structure maximises fit, comfort and performance. A better fitting mask is more likely to give you better protection. These SpringFit\u003cspecial id=\"10\"\u003e\u003c\/special\u003e disposable masks feature the Typhoon\u003cspecial id=\"10\"\u003e\u003c\/special\u003e valve, which reduces breathing resistance, heat and moisture build-up. The valve is unaffected by any moisture, and therefore can be used with the same performance under very low temperatures.\u003c\/p\u003e\u003cp\u003eThese masks are extremely comfortable with adjustable straps giving an improved fit. A foam strip around the inside of the mask adds to the comfort and helps form a better seal. The welded nosepiece improves the fit around the top of the mask. The design of the SpringFit™ mask offers greater compatibility with safety glasses and goggles. Protection level FFP2.\u003c\/p\u003e\u003cp\u003eConforms to EN149:2009.\u003c\/p\u003e","brand":"JSP","offers":[{"title":"Default Title","offer_id":54118316802395,"sku":"105267","price":18.28,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/105267_xl.jpg?v=1789775335","url":"https:\/\/www.axminstertools.com\/products\/jsp-springfit-fold-flat-valved-respirator-ffp2-pkt-10","provider":"Axminster Tools","version":"1.0","type":"link"}
